Displays sFlow statistics.
N/A.
This command displays sFlow statistics for your system.
Received frames—Number of frames received on sFlow enabled ports.
Sampled Frames—Number of packets that have been sampled by sFlow.
Transmitted Frames—Number of UDP packets sent to remote collector(s).
Broadcast Frames—Number of broadcast frames received on sFlow enabled ports.
Multicast Frames—Number of multicast frames received on sFlow enabled ports.
Packet Drops—Number of samples dropped.
To display sFlow statistics for your system, use the following command:
show sflow statistics
The output from this command is similar to the following:
SFLOW Statistics Received frames : 1159044921 Sampled Frames : 104944 Transmitted Frames : 10518 Broadcast Frames : 0 Multicast Frames : 1055652 Packet Drops : 0
This command was first available in ExtremeXOS 11.0.
